red lights on stepper motors on
Discussion in 'OpenBuilds Forum Help' started by freon12, Sep 14, 2018.
  1. freon12
    freon12 New
    hi kyo, i ran into a problem with grbl, i'm not sure if soft ware is causing this all red lights on stepper motor driver go on when i plug in usb cable i did not setup grbl yet. before i hooked up "a" on board, xyz motors did jog, the " a" motor is also ok, but not working. this is a sphinx build if this is settings is it possibal to get right settings as i will be using this for carving i am using dq542ma steppers and phoenix control board . thank you
    #1 freon12, Sep 14, 2018
    The red lights usually indicates $4 is set incorrectly in Grbl settings, refer to Spark-Concepts/xPRO
    $4=1 (step enable invert, bool) (Board V1, V2, V3 Matte = $4=0 - Glossy board V3 = $4=1)
    MaryD likes this.
  3. freon12
    freon12 New
    thank you peter i will do change as soon as i get ob machine driver working. i can't seem to get driver for com port to install.
    The XPRO uses FTDI Drivers for the usb->serial IC: Virtual COM Port Drivers
