recommend cutter for foam
Discussion in 'Laser Cutters' started by Abdul Karim, Dec 19, 2015.
  1. Abdul Karim
    Hi
    I like recommendations for a laser cutter that will cut:
    25mm white polyester foam
    25mm polyether foam (40ppi)
    Also if you can suggest alternative cutting options that would be great. I knw that polyether is solid enough to mill. But polyester binds to the blade and creates a big mess.
