Re-Design of all Gantry/Joining plates.
Discussion in 'Share Parts' started by Julius, Feb 24, 2016.
  1. Julius
    Julius Well-Known
    So, I've had the default plates running for a few months now and I can see some areas of improvement. Just documenting my procedure in this thread for the community, if you want to make them too I can share the files.
    I moved the X rails up 15mm and back 25mm, so the cutter is in line with the front of the plate when mounted. Also added a dip to easier access the grub screws in the belt pulleys. Added some slots for your belt to go out of for tension purposes. Center 2 wheels brought closer for a tighter pulley contact. Really bulking up the joining plates as well. Motor mounted on a 45* to allow access to bolts and easier cable routing. Integrated limit switch mount (use a m5x25 in a slot as a "trigger")
    Photos:
  2. Mark Carew
    Great looking improvements @Julius thank you for sharing them with the community. :thumbsup:
