Ramps Stepper Driver Question
Discussion in '3D printers' started by Sc00ter, Oct 7, 2014.
  1. Sc00ter
    Sc00ter New
    I'm currently trying to use an OX router as a 3D printer to print some parts so that I can build a Lautr3k
    printer. X, Z, E axis all working perfectly! Extruder working well too!
    Y axis continues to lose steps. I'm driving 2 Nema 23's on the Y axis and assume the A4988 onboard driver can't handle the load?!?!? I've slowed down feed rate, jerk, and acceleration to the point that it's excruciating to watch it print. 12v 30a Power supply
    Can I just wire STEP-DIR-EN-5V from the Ramps shield to an external driver? Do I have to worry about voltages ie 3.3v or 5v compatibility?
    Scott
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Scott,
    Each stepper motor should have it's own driver (generally software slaved Y & A when two motors are used on a Y axis).
    Tweakie.
