Question - Black Angle Corner Connector and Cast Corner Bracket
Discussion in 'General Talk' started by Guelillos, Jun 10, 2019.
  1. Guelillos
    Guelillos New
    Are the Black Angle Corner Connector and the Cast Corner Bracket functionally equivalent?
    Thank you.
  3. jeffmorris
    jeffmorris Journeyman
    The Cast Corner Brackets have tabs and the Black Angle Corner Connector don't have tabs. I think the tabs should be filed off where the tabs don't go into slots. One example is mounting the 20X80 V-Slot rail to the gantry plates when building the Lead Machine.
  4. Guelillos
    Guelillos New
    OK. Thank you!
    And in one area the Black connectors have an extra somewhat unknown feature: You can mount wheels to them :) to make bespoke carriages for custom ideas
    MFCarew and sharmstr like this.
  6. Guelillos
    Guelillos New
    That additional feature makes a big difference.
    Thank you, Peter!
    The holes are sized to use Eccentric spacers on all sides to adjust for perfect running :)
    MFCarew likes this.
  8. Guelillos
    Guelillos New
