prusa multi material upgrade - can it be used on DIY printer?
Discussion in '3D printers' started by outofstep, Feb 6, 2017.
  1. outofstep
    outofstep New
    Hi , Most of the time i have enough trouble printing with one extruder, but when i finally "master" this I would like to use multi-colour or multi-material for support material......
    So I was interested when learning about Prusa 2 and 4 material upgrade that they have for Prusa i3 MK2
    Original Prusa i3 MK2 Multi Material upgrade kit (preorder) - Prusa Research
    im not sure what electronics and firmware they run on the Mk2, but im hoping it will be compatible with my machine at some point (ramps , marlin)
    Otherwise I might use 2nd direct drive extruder, but probably not the best idea as my X axis is only 20x20 v-slot,
    anyhow , has anyone else liked the look of the system from Prusa ?
    if you havent seen it there is a video here-
    Original Prusa i3 MK2 Multi Material upgrade release - dual/quad extrusion
    cheers ben
  2. snokid
    snokid Journeyman
    outofstep likes this.
  3. outofstep
    outofstep New
    hi snokid,
    good to hear you are getting this
    so will Prusa provide firmware that will be compatible with your electronics / will you need to adapt this firmware?
    cheers
  4. snokid
    snokid Journeyman
    I have a prusa i3 mk2 so it will just be a bolt on...
    Bob
  5. outofstep
    outofstep New
    Good one Bob,
    I Imagine the Multi -material system is aimed at owners of MK2, and I should wait for it to come out to see if others adapt this system for non-mk2 machines.
    I just did small bit of research to find that mk2 has rambo-mini board, which is arduino mega shield
    reprap wiki says rambo board uses marlin firmware,
    so i imagine its just a matter of someone writing / adapting firmware so that Ramps could talk to the break-out board that Prusa uses to drive the 4 extruders,
    cheers
    Ben
  6. outofstep
    outofstep New
    also Bob , i saw this ebay one you had link too as well , but not sure how to run it, i guess a Rumba board can run 3 extruders so no break out board needed,
    also i found this which is similar but has more information on how to do it
    Diamond Hotend - RepRapWiki
    this is where to but it
    The Diamond Hotend
    #6 outofstep, Feb 6, 2017
  7. outofstep
    outofstep New
  8. outofstep
    outofstep New
  9. snokid
    snokid Journeyman
    yeah the color mixing is pretty cool!!!
    I have seen the diamond hotends before they are cool for sure...
    The rumba board is the way to go, by the time you mess with a stepper expander the costs aren't much different...
    this is going to be the year multi color/material that goes mainstream...
    Bob
  10. outofstep
    outofstep New
    yes i think that this is an exciting development.
    but just when i was about to get my machine working I feel the need to introduce a whole new level of complexity !!!!!!!!!
  11. snokid
    snokid Journeyman
    lol I know the feeling....
    start with easy layer color printing....
    Bob
  12. 3D chaz
    3D chaz New
  13. Kaistein619
    Hey outofstep I was reading your question, because I had the same one. I have a question for you, did you ever by the prusa multimaterial upgrade. If you did and it worked could you please tell me how to set it up.
