Prusa i3 Bear Upgrade V2
Discussion in '3D printers' started by pek, Feb 8, 2018.
  1. jay3D
    jay3D New
    NICE.... :thumbsup::thumbsup::thumbsup:
    Pretty much what I had in mind with the Bear Upgrade. :D
  2. xequtor
    xequtor New
    here is my take to make it fit Misumi 20x40 extrusion as Vslot is not everywhere available and the cuts are not as precise as from Misumi.
    Problem I had is the chamfer, looks like left and right is inconsistent but after printing with 0.35 layer it does not matter, it is tight fit, cannot be inserted from the extrusion side, hast to be slided from the top.
    #32 xequtor, Feb 23, 2018
  3. pek
    pek Journeyman
    Did you do that in Fusion 360?
  4. xequtor
    xequtor New
    yes, using your STEP file
  5. pek
    pek Journeyman
    What you can do is to import the source file in Fusion 360 format : src/prusa_i3_bear_full_upgrade_mk3.f3z . Then you will have access to all parts, sketches and parameters. This will be easier to use. Are you knew to Fusion 360?
    Be careful with parts printed vertically, like rod holders. Double check the rail profile dimensions after printing.
    BTW, the difference of your chamfers will not be visible when printing (but it will avoid elephant foot issue, which is why I add these chamfers in some particular places).
  6. xequtor
    xequtor New
    ahh, thanks, did not see the prusa_i3_bear_full_upgrade_mk3.f3z file, the
    I'm not new to F360 but I come from "different" world. Pro/E and MasterCAM
  7. pek
    pek Journeyman
    Ok perfect. Let me know if you are blocked.
    Tip : In this part, I am doing to a "sharp angle" on the corner of the extrusion. This will avoid plastic taking a shortcut while printing, which could then crack when you tight it. You can do the same technique on the inside angles of your "ergot".
  8. xequtor
    xequtor New
    the prusa_i3_bear_full_upgrade_mk3.f3z is the half upgrade, not full
  9. pek
    pek Journeyman
    hahah w.t.f, I will check that :ROFL:
  10. pek
    pek Journeyman
  11. xequtor
    xequtor New
    ahh, missed the dev branch, thx
    much better now, don't have to reinvent the wheel :)
    but still have to edit most of the parts.
    Looks like you invested lot of time in it, respect!
  12. xequtor
    xequtor New
    did you use only M5 for mounting the parts?
    I'm ordering some parts for the build
  13. pek
    pek Journeyman
    yes way too much :D
    It is not build only for me but to be reproduced by lots of makers. And it is a base for other idea I have!
    For bolting printed parts to extrusion yes. For mounting Prusa components to the printed parts you will need few other screws. Check out the Full Upgrade MK3 BOM here : prusa_i3_bear_upgrade/bom.md at dev · gregsaun/prusa_i3_bear_upgrade · GitHub
  14. xequtor
    xequtor New
    I may go for the V-Slot insted of Misumi extrusion, have to reconsider.
    The only think I cant get ist the power panic modul for MK3, BUT alle info I need is on github GitHub - libxmike/MK3_Power_Panic
    I may order 10-20 PCB to make it, I dont feel like ordering the MK3 power suply from Prusa for 80 EUR just for the power panic modul which will cost maybe max. 5EUR
  15. pek
    pek Journeyman
    Wise decision :D . I do not know where do you leave but if you would like to have precise cut checkout RepRap 3D Printer Parts Supplier - V-Slot CNC - Ooznest . Here is a list of shop selling V-Slot : prusa_i3_bear_upgrade/openbuilds_stores_list.md at dev · gregsaun/prusa_i3_bear_upgrade · GitHub
    The most important cut is the 290mm v-slot for the top. For other length, 0.2mm margin is more than enough.
    Do you already own a 24V power supply?
  16. xequtor
    xequtor New
    I'm in germany, in Belgium they cut with accuracy in the range of 0.5-0.6mm
    The pre-cut V-Slot in UK shop for full MK3 upgrade runs for about 80 EUR incl shipping, Misumi 35 EUR, so I dont know.
    I do have new 24V PSU from MeanWell which was ment for Ultimaker Alu build but had small PSU and did not used heat bead
    #46 xequtor, Feb 24, 2018
  17. pek
    pek Journeyman
  18. pek
    pek Journeyman
    Yes shipping and taxes are very high, same problem for my country. You do not have high shipping cost/taxes if you purchase from Belgium?
    I cannot purchase from Misumi because I need to be a company...
    Maybe you can ask if they can do more accurate cut (and even propose a bit of extra money). I suspect they gives this margin "just in case" but it is quite easy to go under 0.5mm...
  19. pek
    pek Journeyman
  20. xequtor
    xequtor New
  21. xequtor
    xequtor New
    the MK3 full upgrade vertical V-Slot profile, is it 356mm or 354mm?
    according to BOM it is 356mm but in F360 it has 354mm
  22. pek
    pek Journeyman
    Are you sure you have the latest version of source file? The last version is 359mm. But you were right, BOM was wrong with 356 instead of 359mm (I have fixed it).
  23. xequtor
    xequtor New
    I have the source from few days ago, will get the new one
    will the 359mm stay? i may order the set today if the chinese seller will drop the shipping price
  24. pek
    pek Journeyman
    Should stays but as I explained I could not build the MK3 full upgrade as I do not have the chance to own one!
  25. xequtor
    xequtor New
    ok, if you need some dimension from the MK3, let me know I have the original MK3.
  26. pek
    pek Journeyman
  27. jay3D
    jay3D New
    Just checked the suppliers for tolerances:
    - Belgium: 0.5-0.6 mm
    - Italy: 0.5 mm
    - Portugal: unknown
    - UK: 0.2 mm
    - Poland: do they even sell pre-cut 2040? only found the kit.
    - Canada: 1.0 mm :jawdrop:
    I guess I will order in UK than. :)
  28. xequtor
    xequtor New
    can we use instead of 359 mm, 360 mm ?
  29. pek
    pek Journeyman
    Looks like I have to create my store :D
    For Poland, they only sell a pre-cut kit for half upgrade (for now, maybe they will sell full upgrade after the official release...)
    Sure, no problem, nothing to adapt! You will just have 1.2mm on top of the z_tops. The 290mm v-slot will be higher by 1mm as well, which is not a problem.
  30. xequtor
    xequtor New
    I dropped the idea ordering V-Slot extrusion from china, set will cost $52.05, parts $14.50 and shipping $37.55, who know what the cut quality be. Will order in UK, the extra 20 EUR is OK the get is in better quality
    I will order bei Aliexpress just the bolts, nuts and corner brackets as they are much cheaper as in UK or EU
    #60 xequtor, Feb 25, 2018
