Protoneer Raspberry Pi CNC
Discussion in 'Controller Boards' started by gstprecision, Nov 5, 2018.
  1. gstprecision
    Allright guys, bear with me here, I am very new to the CNC world, and especially building from scratch.
    I will be building a C-Beam plate maker, kit is on the way. I am planning on running a Raspberry Pi 3 with the Protoneer Raspberry Pi CNC Hat. I will be using external driver, still deciding which ones.
    There seem to be many different version of the Pi CNC I can see others built on. Some have Arduino Uno, I believe, attached to them. Is this necessary or the newer version of Pi CNC has it built in?
    Any other information will be greatly appreciated.
    GST
    rjd1234 likes this.
  2. Frank Nobrega
    The Protoneer CNC Hat has the Arduino built in.
  3. gstprecision
    Thanks Frank. I will be ordering one this week. I just finished putting my C-Beam plate maker together.
    GST
  4. Frank Nobrega
    Don't forget to get the external driver board adapter.
  5. Brian
    Brian New
    Hey, I'm looking to do the same thing, how'd you make out with the Protoneer hat?
  6. KE6MTO
    KE6MTO New
    Brian, while I can't add a lot as I'm still building my machine but I'm using a RPi3 & Protoneer hat. At this point I'm waiting on some standoffs to finish mounting it them my machine should be ready.
    -Chris
  7. Troy Proffitt
    Troy Proffitt Journeyman
    I use the protoneer Pi3CNC board on my CNC and use BCNC / Raspbian to run it. I have had no problems with it in about 2 years. I use VCNC so I can use my tablet to control everything. As for the external drivers, I used these: DQ542MA Stepper Motor Driver
  8. Brian
    Brian New
    Awesome! Thanks for the info!
  9. Troy Proffitt
    Sorry, it's VNC to connect your tablet to the Pi3/Protoneer, not VCNC :)
