Problems with tinyg motor 3 slot on Y axis
Discussion in 'General Talk' started by gazingm42, Mar 4, 2017.
  1. gazingm42
    gazingm42 New
    So I finally got every thing connected on the tinyg. I have motor3 and motor 4 on the y-axis. I set
    $3ma and $4ma to = 1. I can turn the motors flex coupling and every thing turns find by hand.
    But when I connect to universal G code sender and hit the y+/- the motor 4 turns fine. But appears
    to be no movement on the motor 4.
    I disconnect the lead screw on both sides for testing.
    So just the motor is connected to the flex coupling. I up the step to 5 in on the universal gcode sender to
    see the motor rotations better.
    If I click the +/- I see motor 3 move several turns. But motor 4 moves only a degree or 2. So I thought I
    might had a bad motor. So I changed the motors for 3 and 4. But only to find the motor connect to motor
    4 output on ting moves only a few degrees.
    The trim pots are set between 4 and 8. I moved them motor 3 slightly to left or right with no change.
    Any suggestions? Setting?
    #1 gazingm42, Mar 4, 2017
  2. Giarc
    I do not know much about Tinyg so I may be wasting your time, but on other control boards (at least the arduino based ones I am familiar with) there is a jumper you have to set to slave two axis together. For example on the cnc shield the axis are labeled X,Y,Z,A and A can be slaved to any of the other 3.
  3. gazingm42
    gazingm42 New
    Problem fixed... I discovered the $3tr=1.25 was the same on $1tr and $2tr. But on $4tr it was 3.60. Changing it to 1.25 and reconnect the leadscrews etc all works.
  4. TrishC
    TrishC OpenBuilds Team
    Great. Glad to hear you go it working!
