Problem connecting with GRBL controller
Discussion in 'Controller Boards' started by Sabrina Romero, Jun 19, 2019.
  1. Sabrina Romero
    Hello!
    I moved the controller and made the positive and the ground cable touch. I haven't been able to connect ever since, and it worked perfectly before. Is there a way that I can check what the exact problem is and fix it?
    Thank
    Short likely burned something
    Check for visible burned tracks/melted bits/etc
    Make sure the short didn't kill your power supply or PCs USB port
    But i have a feeling you are in the market for a new controller, shorts are never a good thing
