Platform that travels up and down
Discussion in 'General Talk' started by EasyEd, Dec 18, 2017.
  1. EasyEd
    EasyEd New
    I have a similar problem to this thread from three years ago.
    https://openbuilds.com/threads/small-scissor-lift-with-the-lead-screw.590/
    I need to suspend a platform that is 2' x 2' about 6" off the ground and be able to raise it to 14" and lower it back down to 6". There is a 16"' tall enclosure (container) around the entire platform. I'm considering a scissor type lift or using a pneumatic cylinder lift. What are your thoughts? A drawing is attached.
    How much load are you looking to lift?
  3. EasyEd
    EasyEd New
    Great question. 300 lbs +
  4. Rick 2.0
  5. EasyEd
    EasyEd New
  6. EasyEd
    EasyEd New
    I'm wondering what would be the lightest weight material you could use in the scissor mechanism that would still be able to lift at least 300 lbs?
  7. Sprags
    Sprags Well-Known
    helium would work..
  8. Gooshpoo
    Gooshpoo Well-Known
