Plate maker build. Help needed.
Discussion in 'CNC Mills/Routers' started by THE LINK, Jul 25, 2017.
  1. THE LINK
    THE LINK New
    Hey all,
    I was building some 3d printers and needed mounts, worked out the price and decided to make a plate maker.
    Im thinking open builds XY table woth 2040 extrusion but cant think of a good Z solution.
    Extrusion I have
    2020 X8 500mm lenghs.
    2040 X4 400mm
    2040 X4 350mm
    2040 X4 100mm
    2040 X4 150mm
    Idea is the XY table so each large lengh has a smaller lengh which has wheels but I would like to change this. I would also like to have my screws go threw the smaller blogs and use a linear rail.
    Ive kind of worked the XY but stuck on the Z. The larger 400mm lenghs and 150mm leghs are for Z and maybe for X.
    Im calculated enough for 2 builds depending how I go with Z. Smaler lenghs are to be used as plates basicly.
    Will be using T8x2 as its affordable.
    Will belts with wheels handle 3mm plate making?
    Has any one done a similar build?
    I need a cheaper solution for wheels of can I use u groove bearings?
    Should I grab open rail and u bearings?
    I have a lathe here, what material for them wheels?
    Im throw a bunch of random pics of what Im looking at, I have 2020 I cant cut for bits here and there aswell as ise for support framing. Im going to grab some aluminium rods too but no idea what to do for plates as I aint paying then prices for gantry plates. I need to many same as the wheels.
    Let me know if belts will be ok on X and Y.
    Think Il be mounting motor at top of Z and pulling the XY table up but not come up with anything yet.
    Will try 3d print end caps for 2040 to mount T8 nut and use my extrusion as a plate to mount too.
    Any help or solid advice welcomed.
    Where is cheapest for trapezoidal T8?
    I seen a video of some one make these before and mount them together.
    4 lenghs of 400
    4 lenghs of 350
    350 for xy
    400 for z
    150 and 100 for carriages.
    Not sure though as we would have 2 Xs then lol my head trying to take alot in.
    I will do some moch ups when it arrives but I moched against 2020 and it looks right just not sure on Z.
    So im basicly making a bunch of linear actuators and going to mount 2 together to get all round movement.
    Not sure on spindle ect yet but 100mm there for that and T8 is cheap in 100mm.
  2. THE LINK
    THE LINK New
    I could use the table as Z and X then throw a actuator under for Y movement? That makes sense took all day lol.
    I been looking at it from XY with seperate Z.
    Any advice appreciated. Could do like a crane Z or post with XY table mounted.
    Any pics of buikds similar ive searched hard but no real joy.
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
