Planet CNC Mk3/4 and DQ542MA Stepper Motor Driver
Discussion in 'Controller Boards' started by aj1, Dec 6, 2016.
  1. aj1
    aj1 Well-Known
    Hi guys,
    I'm building my first CNC and I already ordered all the mechanical parts for an R7 CNC build. I was suppose to get the X-controller from inventables because I wanted a plug and play solution but decided to go with the planet CNC controller. I need a little help on the other components that I need. I'll be using 4 nema 23 high torque motors. With this combination, will one 24v/14.6A power supply be enough to power the whole system? Thanks!
