Ox CNC Router Belt tensioning
Discussion in 'CNC Mills/Routers' started by Marcus1, Jun 23, 2017.
  1. Marcus1
    Marcus1 New
    I seem to have quite a few issues creating circular cuts and diagonal cuts - wavy lines created not smooth.
    I am convinced this is down to belt tension. I have printed some tensioning systems, but find that these cannot tension the belts enough.
    What solutions are out there? Pehaps a cam system that will allow to relieve tension overnight? Perhaps a rachet system.
    Any Ideas gratefully received:):)
  2. Gary Caruso
    dual belt!
    any pics of what you are seeing? can be a few other things other than belts, like wheels too tight or loose pulley.
  3. Marcus1
    Marcus1 New
  4. Gary Caruso
    if you are running dual belt the bottom belt is glued and no need for tension other than getting the part between the wheel and the pulley tight.
    Whats your DOC on the first pass? is it making the wonky parts on the finish only? can you post your cnc file?
  5. Marcus1
    Marcus1 New
    Gary
    Dual belts yes - glued no
    I did read an article saying that there was no need to glue
    As to the DOC - 3.4mm 3 passes in MDF Finish full depth
  6. Gary Caruso
    The file does look real good, i pulled up the g-code in my UGS
    Your feed rates are real fast but might be ok, maybe i run too slow!
    What does it sound like? do you hear the endmill digging in and chattering?
    Regarding glue or double sided tape, IMO makes it worth while or tension is an issue.. and the belts still allow deflection then, although it would be double the resilience in theory. BUT Unless you have about 0.5mm of something in-between the lower belt and the rail there is a bit too much slop between the belts. The way i did mine worked very well, but i'm not sure its a great way as it took me three tries to get it right. I used 0.6x5mm carbon strips under the belt glued with rubberized CA (could use rc car tire glue) it bonds very well to the belt (it's permanent, belt is destroyed if you try to pull it off) the carbon makes the distance perfect. Then for the ends i just have end-caps screws holding the ends down. An easier way is the double sided tape easy to find 0.5mm thick tape. (all of this is in my build )
    also curious what your Z looks like do you have a C-beam Z or a 2060 standard Z, router mount solid?
    cheers
    Gary
  7. Marcus1
    Marcus1 New
    Gary
    No noise from the cutter - smooth, it is a surprise when I take the board out and clear the cuts that I see this finish.
    with the dual belt - if you glue the bottom belt down, do you just interlock and clamp together at each end?
    I have the standard OX Z axis and have printed to router mounts to give support all the way up and reduce any "swing" Tension.jpg Tension.jpg Z1.jpg Z2.jpg
  8. Gary Caruso
    Marcus,
    yes you just interlock and hold down the ends so they can't move around.
    The reason why i say it took 3 tries..
    1st) i used too much glue, made a mess, not fun cleaning CA off aluminum even with acetone.
    2nd) Flipped the gantry, i got it down clean but i didn't pre-tension the glue down belt at all.
    3rd) For the Y's i glued down one end about an inch, clamped it at that end then applied the rest of the glue and pulled tight (probably 5-10 lbs-force) before setting the belt into the glue, then clamped that end. That worked great although i have no issues with any of them. this is how i would do it next time as well.
    I'll be cutting some half inch mdf this weekend maybe i'll run your file, see what i get.
    Gary
    Marcus1 likes this.
  9. Marcus1
    Marcus1 New
    Gary - Thanks for that. Just been reading your build, some great ideas in there!
    Could you take a picture of what works for you in Mach 3 - especially the General config!
    I need to eliminate the error and it is compounded when it could be the Cad elements created, the code generator, mach 3, or the machine!!!
  10. Gary Caruso
    Thanks! I'm using grbl (arduino uno) and ugs can't help on the mach3 sorry
