OX CNC 4'x4'
Discussion in 'CNC Mills/Routers' started by zann68, Dec 28, 2015.
  1. zann68
    zann68 New
    zann68 published a new build:
  2. zann68
    zann68 New
    I have included the STL files I made for my Electronics Box and for the Camera Mount for the Bore Camera. Will need to update the camera mounting but you get the idea. The shelf design I copied from DazTheGas build, simple but perfect for mounting those other bits that need a home. The new 3D Printer is getting a workout.
    I decided to go large with the electronics box. I had everything stuffed in a 10"x10" box before. I found it crowded and could not add anything in it and hard to get my hands in it. I decided to go BIG. The drivers are mounted on 2 sticks of 10x10. The box will have a Clear face plate once the wiring is done.
    #2 zann68, Dec 28, 2015
  3. zann68
    zann68 New
    I finally got a chance to wire up the New Break-out board for the new drivers. It's alive and moving! Wrap up some of the other wiring this week and it's done. I still need to to wire up the sensors, camera and kill switch. Still waiting on the Z Axis limit sensor to come in.
  4. Steve Marsh
    Question but not about your router which is nice BTW. In the background of a few pics you have a cnc hotwire foam cutter. Which type of board are you using to control it?
  5. zann68
    zann68 New
    4 Axis TB6560 CNC Stepper Motor Driver Controller Board Kit,57 two-phase,3A.US . eBay item number: 191747491538. I use this on the Hotwire cutter. I used to use this on the CNC as well. I have never had an issue with these boards. I like that they are compact and was able to mount them on or by the motors as well.
    Steve Marsh likes this.
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
