Opening DXF in Openbuilds CAM...part is different.
Discussion in 'CNC Mills/Routers' started by Rick Phillips, Jan 17, 2024.
  1. Rick Phillips
    Hello all,
    I have just built and tested my new OB LEAD 1515. I am very impressed so far. I am fairly new to CNC world. Here is the issue I am having. My workflow is to create a part in OnShape, export the 2D shape as a DXF (V14), open the DXF in Openbuilds CAM then cut the piece. However, when I open the file in OB CAM the shape is different, specifically several of the minor arcs are major arcs. I am very frustrated with this at the moment. I do not want to learn a new CAM software nor do I want to change my CAD software. I have included images of an example piece. Please advise.
    make sure to export as DXF R14 and also make sure all lines are polylines
  4. Rick Phillips
    Peter,
    Thank you for your reply. I read the documentation that you provided. I made sure to "Export splines as polylines" and in Release 14. All this in the current version of OnShape and still it is not loading correctly. I brought the exported .DXF file into Inkscape and saved as .SVG. It loaded better, but it was loading as many different vectors and not a closed shape. So this is still not working. Please advise.
    Rick Phillips
