OpenBuilds OX CNC Machine
  1. Evan Price
    In my experience, you would be better off sending the company you found the dxf. It is a pretty common file type for these applications.
  2. Jonathan Trinity
    I think you are right but i'm always afraid that they will cut wrongly.
    About the gantry plates having 5mm instead of 6mm. Could it be a problem in the end?
  3. Rick 2.0
    5mm plates will have 42% less stiffness than 6mm plates which means they will be considerably more flexible. How much of an impact that will have is hard to say as nobody really knows how much extra stiffness the 6mm plates have to spare.
  4. Jonathan Trinity
    Thanks Rick. I think i'll continue my search for the ox gantry plates with 6mm...
  5. GrayUK
    Jonathan T.
    Sounds like you need the services of Mr Robert Hummel. :thumbsup:
    He is the man to make you a complete set of Gantry Plates. They are the best around, and you won't be disappointed, I can assure you, with the quality and finish. He is not cheap, but these parts are so important, to having a precise and accurate machine, the extra cost is well worth it.
    Go to the top of the page and open Members, Notable Members. you will see his name there. Click on it and open a Conversation with him. I'm sure he'll give you all the details you need. :)
    Gray
  6. Jonathan Trinity
    Thanks GrayUK.
    I already contacted Mr Robert but i live in Portugal and in the end i will end up paying about 500 dollars or more for the kit because of customs. It's a deal breaker to me. :(
  7. GrayUK
    Okay then, Jonathan T.
    Get the 5mm set made up, and build your machine. Then, when you have a machine, use it to make a better one! :thumbsup:
    Guys do it all the time, even out of MDF and hard plastic! Make a "bare essential" one to start with. It's one of the few machines that can then, with care, be used to rebuild itself! :D
    If money is tight, use mid range motors instead of powerful ones to start with. Don't go for a really big machine, just one which can make the new bits for you.
    Small steps my friend :rolleyes:
    Gray
  8. Rick 2.0
    I'm currently working up a mini-mill for this very reason. :)
  9. GrayUK
    Yup. Me too.
    Then a Blue laser machine after that for burning.
  10. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    5mm should be fine
    :p Ty !
    I'm cutting sets as I wait for the wheels, they are a day out :thumbsup:
  11. Jonathan Trinity
    Thanks guys for all the help. I'm a little lost in CNC World but i'll make it. I'll try to find some plates with 6mm but if not i will use the 5mm ones and then i'll probably make the new ones.:)
    Last question for today.:oops:
    Is there dxf files with other parts in mm? threaded rod plate, and others? :p
  12. GrayUK
    I haven't looked myself, but I think Robert Hummel has put up all the files on the parts he makes.
    Have a look at his, Builds - Files, on his Personal Profile. I think they are all in Sketchup Format, but you can easily download that Program.
    Gray
    Robert Hummel likes this.
  13. Jeferson SImoes
    No one?
    trigger likes this.
  14. Jonathan Trinity
    I found the files and i installed sketchup. in sketchup i saw that i can export to 2d graphics.:) but they are in inches..how can i convert them to mm without mistakes in meaures?
  15. Frederic Goddeeris
    It's a chicken or egg problem, is it not... what was first, a CNC machine or gantry plates? :banghead:
  16. Frederic Goddeeris
    Hi Jonathan,
    Have you considered Chris? I believe it is 150 dallar with shipment in the US + a bit more for Europe, perhaps 200. You will not pay 300 dollar to customs...
    There is also the openbuilds shop in the UK who make them, but they are more expensive I think.
    Frederic
  17. Frederic Goddeeris
    How do you measure it?
    Frederic
  18. James McKeand
    If the "Inches" is grayed out, you will need to change the format to "Decimal" to change be able to change units to anything else.
    "Architectural", "Engineering" and "Fractional" all default to imperial units ("Engineering" = Feet, others = Inches).
  19. GrayUK
    Hi Frederic.
    Indeed my friend, it is a conundrum. :rolleyes:
    I would hazard a guess that the Gantry plates came first, for you would not have a CNC machine without them. :thumbsup:
    Plus, Gantry Plates can be made by hand and saw.
    But the Chicken and Egg idea is pleasing to the mind. :cool:
    Gray
  20. Jeferson SImoes
    If someone share a picture of a PCB millied by OX, we can see how much backlash is there.
    In my first V-slot machine, with gt2 2mm, I did this:
    I Did some movement testing through the arrows of UniversalGcodeSender, making some squares, with each line always moving every 5mm.
    Unable to accurately measure the size of the gaps, but they are much visible.
    I'm finishing a new machine with gt3 belt now. With a Dial, I mensured 0,2mm in backlash. This is too much to make PCB.
  21. Chris Laidlaw
    Chris Laidlaw Well-Known
    Even more important than the difference between 5mm and 6mm is the type of aluminum.
    Tempering can make the aluminum over 200% stronger.
    I use T6/T651, 6.6mm thick aluminum to make the gantry plates.
    Chris ([email protected])
    From wikipedia..."
    Mechanical properties[edit]
    The mechanical properties of 6061 depend greatly on the temper, or heat treatment, of the material.[2]Young's Modulus is 10×106 psi (69 GPa) regardless of temper.[3]
    6061-O[edit]
    Annealed 6061 (6061-O temper) has maximum tensile strength no more than 18,000 psi (125 MPa), and maximum yield strength no more than 8,000 psi (55 MPa). The material has elongation (stretch before ultimate failure) of 25–30%.
    6061-T4[edit]
    T4 temper 6061 has an ultimate tensile strength of at least 30,000 psi (207 MPa) and yield strength of at least 16,000 psi (110 MPa). It has elongation of 16%.
    6061-T6[edit]
    T6 temper 6061 has an ultimate tensile strength of at least 42,000 psi (300 MPa) and yield strength of at least 35,000 psi (241 MPa). More typical values are 45,000 psi (310 MPa) and 40,000 psi (275 MPa), respectively.[4] In thicknesses of 0.250 inch (6.35 mm) or less, it has elongation of 8% or more; in thicker sections, it has elongation of 10%. T651 temper has similar mechanical properties.
  22. Rick 2.0
    @Chris Laidlaw,
    I need to provide a little background information here as strength and stiffness are two entirely different and unrelated concepts.
    Strength is something that will almost never come into play with the machines built here. To push a piece of aluminum to the point that it is irreparably bent is the only time the strength of the material has come into play. Strength does not come into play until the material is pushed beyond its elastic range, i.e. the range where it will flex and still flex back to normal. And while strength is a factor in the limits of the elastic range, the usability of the system will be fatally diminished long before it reaches those limits. Stiffness on the other hand is something that is extremely important here. Stiffness functionally controls the amount of flex in a system and controlling flex is important to controlling the track the bit is taking. Stiffness also helps control bit chatter.
    The best example of the difference between the two would be a long gantry beam and a router carriage traversing it. Stiffness of the beam will determine how much the router is deflecting at the center and whether that deflection be 0.5mm or 2.0mm or 5.0mm is extremely import in the outcome of the milled product. Strength of the beam on the other hand will not come into play until the beam has deflected many, many times that amount at which point it has left the elastic range and the material will have started to yield.
    So where does stiffness come from? Stiffness is based on the Moment of Inertia (I) of the member and the Modulus of Elasticity (E) of the material. While strengths of aluminum can vary widely, (E) for aluminum is fairly constant in the 10.0(x10^6) to 10.2(x10^6) psi range. So realistically, the only way to control stiffness is to control the moment of inertia of the member. The moment of inertia for a rectangular cross section is I = b*(t^3)/12 with b=width of the plate and t=thickness. Running the equation through for both 5 and 6 mm thick plates is where my 42% difference number came from. Where the importance of this comes into play with end plates is when the carriage is making sudden movements laterally, the flex in the plates will determine the amount of the temporary overshoot in the bit's tracking. The stiffness of the end plates will also have an impact on bit chatter.
    Unfortunately, there is insufficient data to say what the recommended thickness of the end plates should be and when combined with the range of router and carriage weights, there is really no way of knowing what the minimal acceptable thickness of the end plates is. So in this case if 5mm is easy to acquire and 6mm is not, start with 5 and move up if it doesn't work. Most of what is done on this forum is trial and error as the users here don't have huge r&d or engineering budgets.
    And if all the above sounded like Charlie Brown's teacher (waaa....wawawaa....wawa...waa...wawaaa...), sorry but that's about the only way could come up with to explain it. I hope it helps.
  23. Chris Laidlaw
    I suspect you will find a difference in the stiffness of annealed 1/4" aluminum (6061-O) verses tempered 1/4" aluminum (6061-T6/T651)
  24. asb_79
    asb_79 Well-Known
    Rick 2.0 posted a pretty clear explanation of the difference between the strength and stiffness characteristic.
    Generally speaking Aluminium of any grade 2024, 5083, 6061 etc etc, although they can have widely varying strength have a similar "modulus of elasticity" to within a few points. An interesting point to note; 2024-O is generally regarded as a "general purpose" Alloy with a low yield strength (~76Mpa) has a Modulus of elasticity of 73.1 GPa, 6061-T6 generally regarded as a high strength material (and it is) has a yield strength of 276Mpa and it's Modulus of elasticity is 68.9MPa. (Refer to http://asm.matweb.com/)
    What I am trying to say is if you had two identical sets of plates, one made from 2024-O and one from 6061-T6, under the same load conditions (and assuming you stay withing the stress limit of the 2024). The 2024 plates will deflect less.
    So anyone making plates from Aluminium, the biggest factor that affects performance is the plate thickness more that it's strength properties. On these types of machines I would find it highly unlikely we would ever reach the stress limit of even the lowest strength Aluminium.
    For what it's worth Kram242 made his OX with Fiberglass plates and it works perfectly fine.
    Mark Carew and Robert Hummel like this.
  25. asb_79
    asb_79 Well-Known
    Even at 5mm your plates would be more rigid than the original fiberglass plates used on the Original OX. If that's all you can get, or will save you significant money then go for it.
    There is a DXF of the plates in a thread I posted (Waterjet Gantry plates) in the Forums
  26. Jeferson SImoes
    This video show my try to mensure the backlash.
    https://www.dropbox.com/s/7hn9wzjz2kmmfvm/Backlash V-slot GT2-3mm.avi?dl=0
    I tryed a lot of things. Played with microstepping, all Grbl configurations, very tight and very loose belts. I put regular m3 in the pulley to get a very tighten pulley/shaft.
    No load. I'm assuming that the backlash in gt3 belts is not too much, but, the direct belt/motor setup adopted that "amplifies" the stepper angles error.
    I start to think 26.67 steps/mm (1/8 micro) is to low. In full-step this is about 3.33.
    I can achieve some about 20000 mm/min, with 5000 mm/s^2 without lose steps. Only for test, of course. With a milling machine I don't need this. I'm comfortable with 2,000mm/min and up to 200 mm/s^2.
    I will try a reduction system. But is hard to find gt2 3mm pulley with few and lot of teeth. I will start with 16/40 gt2 2mm that I found in RobotDigg, but I will need a lathe to make the shaft, because the pulley's bore are in different size.
    I will appreciate if someone can do a similar test. Just some engraving square/circles in the spoilboard with very little depth, to clearly show the junction point of the square or circle, for example.
    Unfortunately, neither here, neither shapeoko forum, I found practical information about mesured backlash with our direct driven gt2 2mm or 3mm. Should I start a new post in this forum, to get more visibility to this issue?
    I already finish the new (prototype) Z axis, with chinese ballscrews. This one have about 0.01-0.02mm backlash. Same motor/driver/arduino.
    :cry:
    trigger likes this.
  27. GrayUK
    Okay Gentleman. :)
    I would like to throw in another assertion, based on no formulas, or intelligence really. :D
    Two pieces of 3mm Aluminium, laminated, would give a lower degree of flexibility than one 6mm piece. :thumbsup:
    (Form of lamination is for another discussion at a later date)
    The floor is yours. :cool:
    Gray
  28. Chris Laidlaw
    " 6061-T6 generally regarded as a high strength material (and it is) has a yield strength of 276Mpa and it's Modulus of elasticity is 68.9MPa. "
    On a project I was working on a couple years ago I found out the hard way that 6061-T6 is much harder to bend than Annealed 6061 (6061-O)
    I designed and machined this mold to make boy scout clips out of 1/16" aluminum. I made the first couple out of 6061-O, and they were perfect... easy to bend and adjust, but when I ordered the material from McMaster-Carr to make 200 of them I bought tempered aluminum (6061-T6) because it was a little cheaper than 6061-O at the time. It was a lot harder to bend and adjust. I even tried putting it in our annealing oven to make it softer to no avail... getting the temperatures, and times at the various temperatures, and cool down rates just right to do it turned out a lot harder than I thought it would be.
    #1198 Chris Laidlaw, Aug 23, 2014
  29. Chris Laidlaw
    #1199 Chris Laidlaw, Aug 23, 2014
  30. Jonathan Trinity
    Thanks for the help guys, very nice explanations.
    Yesterday i spent all day searching for someone that could make the plates in the cities nearby. Well i found a company that make the plates with 6mm 5754 aluminium. I think it will work great. :).
    I saw that they had V-Track instead of V-slot... :banghead: what are the diferences...?
