Openbuilds Lead Screw Travel per Revolution (Atmel)
Discussion in 'CNC Mills/Routers' started by Kevin Paris, Mar 9, 2020.
  1. Kevin Paris
    I'm attempting to configure the "Travel Per Revolution" parameter in Atmel Studio 7. I am using an Openbuilds C-Rail lead screw assembly with 8mm lead, and the reduction pate. Since the pulley ratio for the reduction plate is 1:1, I assumed the travel per revolution would be equal to the lead, which is 8mm. When I used this value, however, the gantry plate only moved about a quarter of an inch. I'm using a Nema 23 (200 steps per revolution with 1/8 microstepping). For the sake of testing, I switched the value to 1.25, and again told it to move 1". It's now much closer, though I'd like to figure out mathematically which value I should be using. Any ideas?
  2. Christian James
    Christian James Journeyman
    If it's an 8mm 4 start Trapezoidal lead-screw, I would expect it to move 8mm per revolution. Also, your steps per unit (if it means steps per mm) would be 200 I would have thought (until you're ready to do fine calibration).
  3. David the swarfer
  4. Wick
    Wick New
    360degrees (one revolution) divided by step angle (1.8) = 200 step per revolution.
  5. Alex Chambers
    Full steps, yes. But at 8*microstepping it's 1600 steps/revolution.
  6. Wick
    Wick New
