OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    Then its likely been damaged, recheck the page, paying particular attention to section 6.3.1 - you'll want to find what killed it before replacing it
  2. Geoffrey "Tiny" Turner
    I did nothing, added nothing, it was running fine then just stopped. What has it killed? is it my laptop or the controller, if it is the controller how do I fix it or replace the usb
    Work through the provided link please it goes in depth on what to look out for, and to diagnose.
  4. AdamD
    AdamD New
    Hi Peter
    $40=1 workaround will now allow me to continuously jog from home position. Will there be an update to take into account terjeio's comments?
    Thank you both for your help.
    Yes:
    AdamD likes this.
  6. JustinTime
    JustinTime Journeyman
    I have a Teensy 4.1 with GRBLHal. Control doesn't recognize the Teensy. Is there a setting to get Control to connect to it and if not, can this be added to Control?
  7. David the swarfer
    I tried a BluePill with the same result, believe that CONTROL is looking for the USB ID of the BlackBox, though it will find a generic Uno/GRBL controller.
  8. Misterg
    Misterg Well-Known
    As a bit of a work-around, you could try compiling GRBL_HAL with a higher compatability setting:
    Compatibility level
  9. JustinTime
    I didn't master the art of compiling the GRBLHal, unfortunately. I wish I would, though! :(
    Its quite easy: http://svn.io-engineering.com:8080/
    Compatibility mode is on Advanced Tab.
    That said, we don't compile grblHAL with compatibility for our controllers. It works just fine without. We made CONTROL work with GrblHAL around V1.0.333 onwards (See OpenBuilds-CONTROL/CHANGELOG.txt at master · OpenBuilds/OpenBuilds-CONTROL )
    We don't check for USB IDs or anything,
    we (1) try autoreset (Arduino/ESP32 style with DTR/RTS) - on boot Grbl sends its standard greeting (Grbl vX.Xx ['$' for help])
    If that doesn't respond after a second or two, we try method (2) - sending Ctrl+X to reboot Grbl in case its running on a board that doesn't support Autoreset
    Again we wait for (Grbl vX.Xx ['$' for help]). If that also doesn't get a response we send "version\n" which is a Smoothieware command (legacy from when OpenBuilds used to sell Smoothieboards) and if we get the response it is smoothy, or timeout on the other two methods, we print out a "no firmware found" thing
    See OpenBuilds-CONTROL/index.js at master · OpenBuilds/OpenBuilds-CONTROL and OpenBuilds-CONTROL/index.js at master · OpenBuilds/OpenBuilds-CONTROL
    So if a 3rd party board is running 115200 baud, and accepts a Ctrl+X over serial and then reboots and prints the startup message - it should work
  11. David the swarfer
    will try it again and see...
  12. terjeio
    terjeio Well-Known
    I can connect to my Teensy controller with CONTROL v1.0.370, no compatibility mode selected.
  13. David the swarfer
    not the bluepill, the PiPico, responds like this
    [15:57:41] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [15:57:42] [ websocket ] Bidirectional Websocket Interface Started Succesfully
    [15:57:43] [ update ] Checking for Updates
    [15:57:43] [ update ] You are already running OpenBuilds CONTROL 1.0.370
    [15:57:51] [ connect ] PORT INFO: Port is now open: COM7 - Attempting to detect Firmware
    [15:57:51] [ connect ] Checking for firmware on COM7
    [15:57:51] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [15:57:51] [ ] ok
    [15:57:52] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [15:57:52] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [15:57:52] [ ] error:9
    [15:57:55] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM7
    [15:57:55] [ disconnect ] PORT INFO: Port closed
    bCNC connects into ALARM state which is expected because there are no limit switches connected.
    Ithink DTR is not resetting the Pico
  14. terjeio
    terjeio Well-Known
    It can not since that will kill the USB stack
    Many grblHAL drivers have "native" USB support meaning that there is no FTDI or similar UART <> USB chip that less capable MCUs needs (8-bit Arduinos, ESP32, ...).
    More info here.
    If the controller boots into, or is in, a "normal" state when connecting CONTROL seems to work fine, here is a log from a Pi Pico connection:
    [16:52:53] [ $$ ] $481=200 ;Autoreport interval in ms
    [16:52:53] [ $$ ] $484=1 ;unknown
    [16:52:53] [ $$ ] ok
    [16:52:53] [ $I ] [VER:1.1f.20230913:pico CNC]
    [16:52:53] [ $I ] [OPT:VNMSL+2,35,1024,3,0]
    [16:52:53] [ $I ] [AXS:3:XYZ]
    [16:52:53] [ $I ] [NEWOPT:ENUMS,RT+,ES,SED,RTC,ETH,FTP,SSDP,SD]
    [16:52:53] [ $I ] [FIRMWARE:grblHAL]
    [16:52:53] [ $I ] [NVS STORAGE:*EEPROM 8K]
    [16:52:53] [ $I ] [FREE MEMORY:130K]
    [16:52:53] [ $I ] [DRIVER:RP2040]
    [16:52:53] [ $I ] [DRIVER VERSION:230828]
    [16:52:53] [ $I ] [DRIVER OPTIONS:SDK_1.5.0]
    [16:52:53] [ $I ] [BOARD:picoCNC]
    [16:52:53] [ $I ] [AUX IO:0,7,0,1]
    [16:52:53] [ $I ] [WIZCHIP:W5500]
    [16:52:53] [ $I ] [IP:10.0.0.69]
    [16:52:53] [ $I ] [PLUGIN:WebUI v0.20]
    [16:52:53] [ $I ] [PLUGIN:SDCARD v1.10]
    [16:52:53] [ $I ] [PLUGIN:FS macro plugin v0.06]
    [16:52:53] [ $I ] ok
    [16:52:53] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
    [16:52:53] [ $G ] ok
    [16:52:54] [ connect ] Firmware Detected: grbl version 1.1f on COM30
    [16:57:07] [ ] GrblHAL 1.1f ['$' or '$HELP' for help]
  15. Peter Van Der Walt
    That would be part of it for sure yes. BlackBox still has usb chips (FTDI and later versions CP2102s) so that's what we have it built for.
  16. Andrew Batty
    Hello Peter, Can I ask you a ?
    I got Openbuilder going on a Mac OS 10.13
    and trying to USB hook up our Genmitsu CNC 3018-PRO Router.
    No black box, just the Genmitsu board on back of the CNC.
    It reads : No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.Bluetooth-Incoming-Port
    That page is now gone.
    Do you know of the firmware or driver for our Mac?
    A download link?
    The read out code is below.
    Thank you,
    Andrew
    [20:04:26] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [20:04:26] [ websocket ] Bidirectional Websocket Interface Started Succesfully
    [20:05:05] [ connect ] PORT INFO: Port is now open: /dev/tty.Bluetooth-Incoming-Port - Attempting to detect Firmware
    [20:05:05] [ connect ] Checking for firmware on /dev/tty.Bluetooth-Incoming-Port
    [20:05:05] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [20:05:05] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [20:05:06] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [20:05:09] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.Bluetooth-Incoming-Port
    [20:05:09] [ disconnect ] PORT INFO: Port closed
    [20:07:35] [ network ] Starting network scan for: 192.168.1.1-192.168.1.254
    [20:07:37] [ network ] Network Scan completed. Found 0 devices
    [20:09:47] [ connect ] PORT INFO: Port is now open: /dev/tty.Bluetooth-Incoming-Port - Attempting to detect Firmware
    [20:09:47] [ connect ] Checking for firmware on /dev/tty.Bluetooth-Incoming-Port
    [20:09:47] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [20:09:48] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [20:09:48] [ connect ] Detecting Firmware: Method 3 (others that are not supported)
    [20:09:51] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port /dev/tty.Bluetooth-Incoming-Port
    [20:09:51] [ disconnect ] PORT INFO: Port closed
    [20:10:15] [ network ] Starting network scan for: 192.168.1.1-192.168.1.254
    [20:10:17] [ network ] Network Scan completed. Found 0 devices
  17. Peter Van Der Walt
    Alex Chambers and dJOS_500 like this.
  18. dJOS_500
    dJOS_500 Well-Known
  19. Peter Van Der Walt
    Yes, that entitles the person to tech support, and it would just work. It contributes to CONTROLs development. Etc
    David the swarfer and dJOS_500 like this.
  20. dJOS_500
    dJOS_500 Well-Known
    You don’t need to justify yourself to me, I added the winky smiley to indicate it was a wind up. I guess it didn’t translate. :cool:
  21. David the swarfer
    does the Genmitsu controller run standard GRBL 1.1?
    if not then CONTROL will not work, but bCNC might.
  22. JustinTime
    I was away over the weekend and when I came back today I powered the machine up. I checked the version of Control and it's 1.0.370 and this time Control connected to the Teensy 4.1.
    Alas...not all was going smooth. I tried the Probe and it worked perfect on the Z axis. I then run a cutting file, without having the motors connected, and none of the limit switches triggered. I then pushed the E-stop and it stopped the machine and disconnected the USB connection. I reset the E-Stop and the port was available again and I could reconnect Control to the Teensy.
    I turned off Control and ran IOSender and the limit switches were recognized with no problem. Nothin in the setting up of the machine was changed.
    BTW, the homing button in Control was grayed out. I can't recall if it was also grayed out when I had the Arduino Nano connected. I do recall that I used it once or twice a long while ago in a old version of Control.
  23. Peter Van Der Walt
    Make sure to set Homing Cycle to something other than 0
    If its just troubleshooting tab, check your report mask. Otherwise, check that Hard Limits is on
  24. JustinTime
    Yeah, my bad, I forgot that the setup is saved on the chip and not in Control. In IOSender it must be default and that's why I had the limit switches work. After I've set the parameter you've mentioned everything is fine.
    I still have a few issues, like the spindle PWM is only 3.3V on the Teensy. It must be a common issue since there is a board, wildly sold, that changes it from 0-3.3V to 0-10V. I have one coming today and hopefully it will rectify this problem.
    The last issue I have is with the E-Stop but I have to check if it's also in IOSender.
    BTW, If I home the Y axis, which has dual motors, will it square it or is there a setting I have to set? I have a limit switch installed on the A axis.
  25. Peter Van Der Walt
    E-Stops MUST cut power. A software pause is useless when the router is busy degloving your hand, or your PSU is on fire. Real history... Not fun
  26. JustinTime
    As you've mentioned in the past, there are two kinds of E-Stop. One that shuts down everything, preventing just what you've said above, and one that works similarly to the Open Door switch. I HAVE BOTH!!! Now I want the latter to work as mentioned.
  27. Peter Van Der Walt
    Fantastic :) - but just remember I can't remember all the thousands of people on here's specific setups (; - and will always advocate for others' safety. So take it for what it is thanks. Good luck
  28. ljvb
    ljvb Well-Known
    How mature is the fluidnc firmware support.. right now, I am having issues with the fluidnc tab and the configuraiton file showing errors due to random messages that the controller throws in the command line when Control reads the config (mpos idle and position location which appears randomly).
  29. Peter Van Der Walt
    Still very much unstable FluidNC support · Issue #283 · OpenBuilds/OpenBuilds-CONTROL with tonne of todo work. We'd love to work on it but this whole year the Dev team has been occupied on an exciting new project, so have had not resources to dedicate to it yet.
  30. Jimc137
    Jimc137 New
    I have a simple Control software question. I am using a router on my SainSmart CNC. When I am machining a complex file with a significant amount of lettering, the router constantly starts and stops as it raises up to the "safe Z" between cuts. I can't image this is good for the router. Is there a command that will just keep the router running constantly until the file is completed?
