Hello, I'm thinking of building a control keyboard with the main functions (X, Y, Z, start, stop, feed) for openbuilds control with QMK-firmware. Now my question is: what are the keybindings for openbuilds control? I know up/down is Y, left/right is X, but what is Z, feed, start, stop, abort?
Click on Wizards and Tools > Customize Keyboard Shortcuts to view the current assignments, or even change them to keys that suit you better
@Peter Van Der Walt Peter, I'm busy with the layout of my keyboard. I want to include a "probe" key aswell. Do you have any idea if "probe" also has a keybinding?
It does not, but you can create a JS Macro: Getting started with Javascript Macros in CONTROL / Library of Macros created by the community and assign a shortcut key to that. Let the JS Macro run the following Javascript function to launch the Probe wizard dialog. Code: openProbeDialog();
Also see @sharmstr 's writeups on her blog: Getting Started With JavaScript Macros in OpenBuilds Control I see she actually did a writeup for Probing keyboard shortcuts here Initiate Probing via Keyboard Shortcuts in OpenBuilds Control - i always forget to check hers too
