OpenBuilds Control AutoRun AutoFocus
Discussion in 'Control Software' started by KaosCNC, Feb 13, 2021.
  1. KaosCNC
    KaosCNC Well-Known
    @Peter Van Der Walt
    s there a way to set OpenBuilds Control on a Windows 10 machine to run at the time of start up and also have it it complete full screen focus ?
    I'm searching but have not found how to do it or if that is even an option.
    It runs on boot, but sits in the tray.
    Add a startup script that runs it a second time, that'll bring up the GUI
  3. KaosCNC
    KaosCNC Well-Known
    when I install it on a PC - it never starts on boot
    I did move a shortcut to starts up and now it appears in the sys tray.
    However, does not come to focus.
    So you are saying with this script the GUI will be in focus? Will it be maxed to screen size ?
  4. KaosCNC
    KaosCNC Well-Known
    I have it now where it will run and be up when I login.
    cannot get the maximized to work.
    In the properties I have it set to maximized
  5. sharmstr
    Maybe try putting this in a javascript macro and set it to run at startup.
    Code:
    window.moveTo(0, 0);
    window.resizeTo(screen.width, screen.height)
  6. KaosCNC
    KaosCNC Well-Known
    Will give that a try.. not sure how to do a javascript macro but will search.
  7. sharmstr
    In control, go into macros tab. Add a new macro. Be sure to click on javascript side tab. Paste code in the box. Put a check on "run at startup".
  8. KaosCNC
    KaosCNC Well-Known
    Bingo... all good now... thank you
  9. sharmstr
    How? I have mine starting up just fine, but how did you get it "up".
  10. KaosCNC
    KaosCNC Well-Known
    I have it in the scheduler as to run when a user logs in. After I did the javascript and rebooted when I typed my pin in to login it OBC was up and full screen.
  11. sharmstr
    Awesome. I didnt even know I wanted this. My Dad is going to be happy about this. :)
