OpenBuilds CAM adding Tabs
Discussion in 'CAM' started by Timothy Pinto, Mar 6, 2019.
Tags:
  1. Timothy Pinto
    I created a toolpath for a vector outside path. I added tabs to it via the intuitive interface. Now I'm getting greedy. I make wood signs, and only need tabs on 2 sides of the rectangular sign. Is there any way to specifically locate tabs, instead of just having uniform spacing?
    Unfortunately no. But, playing with the distance, you can get very different placing as the algorithm does its thing. Try a few different values
  3. mrrweldfab
    How do you add tabs to a project?
    Under the toolpath options' Advanced section:
  5. mrrweldfab
    That's weird.
    Mine only has Geometry: Merge on the Advanced Settings
    You're creating a Plasma toolpath. Tabs are for CNC
