Open Rail - Usage Cases, Benefits?
Discussion in 'General Talk' started by Enterpol, Sep 16, 2016.
  1. Enterpol
    Enterpol New
    I've been a long time user of V-Slot extrusions, but was curious what the usage case/benefits of the open rail is. Why would you use open rail when there are fewer plates/mounting solutions, and less wheels that will work on it? Does it provide a higher level of repeatability/precision? Is it just stiffer due to the added material, a spacing thing, or legacy thing? I'm all about options, but curious where you would use this except where you needed to use the metal wheels since they can be hard on the V-slot. Looking forward to the comments.
    It's a legacy thing but it still does have its uses. It is a great solution if you are wanting to use a larger or stiffer size than v-slot can offer or if you are wanting a wider grip. (Here is an example of a project using it.) And BTW. it should only be used with the Delrin V-wheels. Metal wheels are just as hard on it as they are on v-slot.
