Open rail plate
Discussion in 'General Talk' started by RHightower, Jan 15, 2014.
  1. RHightower
    Will this work on the v-slot extrusions directly or is the spacing off to fit the open rail system?
  2. Mark Carew
    The hole spacing's for the OpenRail plates are not the same for the V-Slot gantry plate
    You can bolt OpenRails directly on the VSlot or any 20 series extrusions and then use the OpenRail plates.
    But you cannot use the OpenRail plates directly on the V-Slot tracks that is what the V-Slot gantry plate is for.
  3. RHightower
    Thanks!
    I wasn't sure. From the picture the open rail plate looked like an easier to deal with size than the v-slot so I figured it wouldn't hurt to ask. :)
  4. Mark Carew
    NP They are actually confused a lot and we have been working on ideas to make them a little more individualized at a glance.
