Open build controlV1.0.253
Discussion in 'General Talk' started by Rod13, Nov 10, 2020.
  1. Rod13
    Rod13 New
    Hi all
    Was trying to run a Gcode file, using a 3/16 VBit. Tried to load the file into control software. It was taking a while to load and then the program went to a white screen. See the attach photo. Is there a bug in the software?
  2. sharmstr
  3. Rod13
    Rod13 New
    The file is 173,000+ KB, this was done in VCarve desktop.
    That is massive, disable the 3D viewer from Troubleshooting Tab > Application Diagnostics, there is no way we'll be able to render a file that big, then you just re-enable for smaller jobs
    The file has just under 8 million gcode moves in it! :)
    Which feels like too many for a simple Photo Carving, are you sure you set all the parameters correctly in Vectric?
    Can you upload the VCarve project too?
    Rod13 and sharmstr like this.
  5. Rod13
    Rod13 New
    Thanks , I will do that. A lot of detail in that file. I will keeps that in mind when I do my projects.
    Thanks Rod
  6. Rod13
    Rod13 New
    Here the project
    Re did the file, using the same tool and carving method. This came out to 369 mb.
