Ooznest OX not cutting circles
Discussion in 'CNC Mills/Routers' started by gareth harvey, May 24, 2017.
  1. gareth harvey
    Have been trying to cut circles on the OX but they all just keep cutting with 'flat' sides. Have reduced the travel speed of x & y axis but nothing changes. This one was 200mm across, used Sketchup to draw.
    Even bigger circles are exactly the same, all have flat sides
  2. Ryan Lock
    Ryan Lock Veteran
    I would check the grub screws on your pulleys are tight, this is usually what you see when they are not tight enough.
  3. gareth harvey
    Will check now, how tight do these need to be, can I 'really pull them'?
  4. Ryan Lock
    Ryan Lock Veteran
    Basically what Justin said. Our shafts do have the flat side, so one grub screw should be on that.
  5. gareth harvey
    Thanks, just got round to looking at this. I tightened the belts but this did not make a difference. I then re-adjusted the rollers on the X Axis and hey presto: It's working. They were just too tight.
    Ryan Lock likes this.
  6. Ryan Lock
    Ryan Lock Veteran
    Hi Gareth,
    Great, glad you got it sorted.
    Ryan
