OB's 345oz. Stepper Motor
Discussion in 'Motors' started by AR15DCM, May 26, 2016.
  1. AR15DCM
    AR15DCM New
    Hello,
    Has anyone ever seen the documentation or taken one apart to know how thick the motor casing is ?
    If it is thick enough I want to drill/tap it so I can mount some heat sinks on them.
  2. dddman
    dddman Journeyman
    You can also use double sided tape (the one made for heat sinks!)
  3. AR15DCM
    AR15DCM New
    I plan on using a Peltier Cooling Plate under each heatsink. Between that and the thermal paste the only option I would think is to drill/tap and secure the heatsink with some small machine screws. And, you can probably guess... M5 x .8's screws to boot! LOL
    That should keep the motors nice and cold during use :thumbsup:
  4. Gary Caruso
    probably be cheaper and much easier to upgrade the motors to ones that can handle the power required.. or turn down the current if you don't need all the power :)
    I think drilling into the motors not a great idea, maybe just straps?..
    looking into this more i found this
    Stepper Motor Heating
    #4 Gary Caruso, Mar 16, 2017
  5. Gary Caruso
