Non magnetic gantry materials
Discussion in 'General Talk' started by Thoreauman, Oct 16, 2015.
  1. Thoreauman
    I am designing a 3 axis gantry to measure magnets and magnet arrays, up to 600mm x 200mm x 30mm.
    I need to keep everything within about 150mm to the magnets non magnetic to not affect the fields. Does anyone know if the lead screws 300 series?. I may go with aluminum shafts from McMaster and plastic sleeve bearings for my Z axis, the rest can be V-groove.
    Not quite a complete question. Please restate.
  3. Ronald van Arkel
    Hello Thoreauman,
    I don't know non-ferrous Acme screws but the M5 screws and nuts are sold made out aluminium; you can find them in the RC and bicycle world.
    -Ronald
  4. Thoreauman
    Replying to Rick 2.0, is the openbuild 8mm acme lead screw made from non-magnetic 300 series stainless steel? Thanks. I am curious if anyone has worked on something similar, measuring magnet fields.
  5. Ronald van Arkel
    Yes it is, the Acme screw is almost non-magnetic. I'm helping out on a military project with V-Slot and they also use it to mount a scanner to the structure.
  6. Rick 2.0
    Almost being the key word there. I have no idea what it is made from but was able to note a slight attraction to a fairly strong welding magnet.
    Are belts an option?
  7. Thoreauman
    I think I will try the lead screw and use belts as a fall back. I will have a long plastic end for the probe. I am using belts for the X and Y. When I have it modeled up I will post it.
    Thanks for the help.
  8. Flash22
    Flash22 Well-Known
    Ronald van Arkel likes this.
