Newbie issues converting svg to gcode
Discussion in 'CAD' started by Matt Thorniley, May 4, 2019.
  1. Peter Van Der Walt
    Refer to Coordinate Systems - for someday - lets say 5 years down the line (;
    Normal uses cases never need coordinate systems. But its for advanced uses like this! Thats why I say, dont bother with it, as it just adds confusion
  2. Alex Chambers
    Peter is spot on @Matt Thorniley, unlike your machine co-ordinates (sorry :rolleyes:) grbl will set your machine co-ordinates zero wherever you switch on - best to ignore them for now. You can use any text editor to delete that G53 line. Set your workplace zero as normal, raise Z 10mm, then run your g-code.
  3. Matt Thorniley
    So again back to the big question...... why was the code running good last night and running poorly this morning. I am stuck. IMG_3457.JPG
  4. Matt Thorniley
    I tried that once and it just did the same. So maybe shut the machine off and back on, reset 0 axis?
  5. Matt Thorniley
    I did go into the editor and remove G53 lines
  6. Alex Chambers
    Sorry @Matt Thorniley, we have helped to confuse you by steering you to @sharmstr's post processor, which puts that G53 line in. We didn't think that you might have a machine without limit switches that would allow you to reset machine co-ordinates whenever you switch the machine on.
    Delete that line with G53, reset your workplace zero (top, front, left of your workpiece) and your g-code should run. You will have deleted the instruction to raise the Z axis 10mm, so do that by jogging before running your file.
  7. Matt Thorniley
  8. Alex Chambers
    PS - I believe that there is a second G53 line at the end of the file, it might be a good idea to delete that too.
  9. Matt Thorniley
    I got it..... did search on it and found it. Thanks
  10. Matt Thorniley
    FYI.....shutting off the machine and starting all over seemed to do the trick
