Newbie Issue
Discussion in 'General Talk' started by Brew Dave, Feb 28, 2021.
Tags:
  1. Brew Dave
    Brew Dave New
    Just assembled my new OpenBuilds 1010 LEAD and have loaded a simple GCODE (lizard from the OpenBuilds library) and every time I attempt to run the job the Z axis errors out at the limit switch. I've re-homed time and time again and get the same result. Please advise.
    Thanks!
    Does each axis jog in the correct directions.
    Did you remember to set zero.
    Appropriate Z values in CAM setup to fit working envelope available?
  3. Brew Dave
    Brew Dave New
    Figured it out! Z-axis wasn't set to zero for the material.
