Newbie Going Nuts
Discussion in 'Controller Boards' started by RJT, Apr 28, 2015.
  1. RJT
    RJT New
    I,like many here, have been bit by the CNC bug. After too much research I'm going to build a large OX. The only thing holding me back is the electronics portion of the build. After reading for hrs (maybe too much). I can't decide on the electronics setup.
    I don't know if I'm focusing too much on the problems people are having.
    I plan to start cutting some wood projects, nothing complex, gears etc.
    I'd appreciate any suggestions on what you think a newbie should use. I don't mind starting off one way and upgrading later once I figure out what I'm doing.
    Is there anything that would be easier to setup and get cutting (get my feet wet with) and then move up (upgrade) to some thing else.
    Thanks in advance for any suggestions.
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
