New PSU for my rostock max killing my fans!
Discussion in '3D printers' started by Jestah, Apr 1, 2014.
  1. Jestah
    Jestah Well-Known
    So after adding a 6mm aluminum heat spreader to my rostock max I decided a BIG 18v psu would help me get it to temp faster....
    Totally forgot that this also feeds far to much juice to my fans and may explain why i have killed a small stack...
    Option 1) run two psu.... PITA.....
    Option 2) Run two 12v dc fans in series from the 18v supply.....
    I would rather go with option two as I feel more peek cooling with help with with my poor retractions and also saves having to install a second 12v supply...
    Any one see a downfall to running with option 2?
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Perhaps another option would be to use a 12Volt regulator, 7812 or similar (on a heatsink) to drive your fans from the 18Volt supply. :)
    Tweakie.
  3. Jestah
    Jestah Well-Known
    Thanks for the idea @Tweakie and I was just about to head to the shop to pick some parts up but using a regulator would negate any fan speed adjustment I have as it would hold the fans at 12 regardless of the power input.
    OR should a peek fan be on full blast all the time?
  4. Jestah
    Jestah Well-Known
    Or by feeding the 12v into the rambo from the reg it should then adjust the fan speed via PWM on the Rambo ?
  5. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    I believe the 7812 IC is only rated for 1.5 amps with a heat sink, if you require more amps look at the LM350t
    It is rated at 3-5 amps I believe and is adjustable
  6. bobt
    bobt Well-Known
    JustinTime - You are right about the noise from cutting but the noise from squirting hot plastic is more of a "Sploosh" or a "Splat" as to a "RIP,WHINE or SCRAPE" noise from a mechanical cutter. So Fan noise can be a real annoyance when using a 3d-printer.
    Bob
  7. Robert Hummel
    Moderator
    If you are simply running the fans and want variable speed then just use the LM317 and adjust your pot for speed control ;)
    Simple, easy, cheep
    #7 Robert Hummel, Apr 3, 2014
