New BlackBox X32 stepper only takes one step.
Discussion in 'General Talk' started by Doug Webster, Feb 17, 2023.
  1. Doug Webster
    I just received my new Blackbox X32 connected to the 24V Meanwell Power Supply
    I connected a NEMA 23 motor to the X connector.
    All controller settings were left at defaults.
    When pressing the Jog key, the motor feels like it engages, the DRO will increment up to the new value, there is no motor movement until the new value is reached, then the motor seems to make one single step. I have tried different motors, different cables, different computers. All the same result..
    I feel like I am missing something simple. Any help will be appreciated.
  2. sharmstr
  3. Giarc
  4. Doug Webster
    Loading the machine profile seems to have resolved the issue.
    Thanks you for your help :)
    (First time using this setup)
  5. sharmstr
    Then please update the firmware as well.
  6. Doug Webster
    I did that first, as you suggested
    Thank you again :)
