NEMA23 High Torque Specs
Discussion in 'Motors' started by JP Scott, Apr 5, 2020.
  1. JP Scott
    JP Scott New
    Greetings to you all, hope everyone is safe, healthy and happy.
    I've just done a search here and am unable to find a complete spec sheet for the NEMA23 High Torque motor. Does anyone have it or can you direct me where to find it...looking for at least...
    Microstepping (interpolation)
    Steps per mm
    Max. Speed Change (mm/s)
    Max. Speed (mm/s)
    Acceleration (mm/s²)
    Motor Current (mA)
    thanks in advance,
    Jim Scott
  2. Giarc
    Steps/mm depends on your mode of transmission (belt pitch or screw pitch) but there are 200 steps per rotation of the motor with no microstepping involved from your controller. They are 1.8 degree step angle motor.
    Acceleration also depends on what mode of transmission you use. So does Max Speed. Pretty much everything you list falls under the "It depends" category due to variables the builder introduces such as the over all weight of gantries, screw/belt pitch, microstepping chosen, drivers, power supply, etc. The spec sheets are on the product page. You have to look at the images. It is not the most intuitive way to provide it.
    #2 Giarc, Apr 5, 2020
  3. JP Scott
    JP Scott New
    Giarc , thank you so much. I had no idea the info was on the product page. I certainly spent a lot of time there. Cheers, Jim
  4. Giarc
    No problem. I knew they were there somewhere, but it took a bit for me to find them.
    All the motor datasheets are in the image galleries of the product, just scroll through the pictures with the little arrow buttons
