Nema23 4A for blackbox
Discussion in 'Motors' started by diler35, Nov 29, 2020.
  1. diler35
    diler35 New
    Hi everyone, I've 4 nema23 4A with MW 24V 350watt power supply, do you think that blackbox can handle for long time Vcarving projects on each motor or it can burn blackbox board on long time use ?
    #1 diler35, Nov 29, 2020
    It will probably run it fine. The 4A rating is the maximum the motors can take without damage, not the recommended current setting. So in terms of current the 3.2A RMS max of the Black will keep it all safe.
    But current is but one part of the equation. Is the coil voltage rating between 3-6v? Low inductance of 1-2mH - those two parameters make for nice and fast acceleration. Check your motors datasheets, if the values differ drastically, post the datasheet and we can advise better
  3. diler35
    diler35 New
    Thanks for replying, i've found the data sheet for motors so if i set the each motor current to 3.2A motors will run normally? motor_specs.JPG
  5. diler35
    diler35 New
    Ok, thanks I'll try that.
  6. A.J.W.E. Klappe
    A.J.W.E. Klappe Well-Known
    Hello Peter,
    What is the default current setting of the Blackbox and can I crank it up that a little. My motors now run at 1500mm/min but not yet 3 or 4000. Would increasing the current do a better job.
    Dit product bevat:
    3PCS Nema23 Stepper Motor 23HS2430
    Belangrijkste parameters:
    Artikelmodel nr.: 23HS2430
    Motortype: Nema 23 hybride stepping motor.
    Stap hengel (°): 1.8
    Nominale spanning (V): 4.8
    Rate Current(A): 3.0
    Fase weerstand (Ω): 1,6
    Fase Inductance (mH): 6.8
    Holding Torque (N.m. Min): 2,8
    Lead Wire(nr. : 4
    Rotor Inertia (maat cm2): 800
    Detent Torque (N.cm Max): 12.0
    Mechanische afmetingen:
    Item Framemaat: 56.4X56.4 mm
    Lichaamslengte: 112 mm.
    Item shaft diameter: 8,0 mm ronde schacht
    Artikelschacht lengte: 21 mm
    Lead: 4 kabels met 300 mm lengte.
    Thanks in advance
    Bert
    The inductance of the motors could be lower - this might be the limiting factor - more inductance = more self-braking back-emf
    Dial back the acceleration a little - so it has more time to come up to speed
    You can happily dial the current up, just check for overheating: See docs:blackbox:currentadjustment [OpenBuilds Documentation]
