Nema 23 mount rigitiy
Discussion in 'General Talk' started by Adam Roberts, Jun 21, 2015.
  1. Adam Roberts
    Hi,
    I am planning to use a nema 23 motor in my build, using the openbuilds bracket, like in the picture I attached. My question is, how rigid will the motor plate be in this orientation? Is the connection provided by the T-nuts strong enough to hold against a typical amount of belt tension, for a 3d printer belt driven system?
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    In my opinion, yes it will be strong enough for a 3D printer belt drive system. ;)
    Tweakie.
  3. Patrick Walls
    I would think more than storng enough.
    Pat
  4. Ronald van Arkel
    More than strong enough, this is why I suggested a NEMA17 motor before, teaming it with a 14t pulley and your done.
    -Ronald
  5. Adam Roberts
    Hi Ronald - I decided to stick to nema 23 since models are available with 0.45 degree step angles. This is not possible using nema 17.
  6. Ronald van Arkel
    I see. Remember that in general your stepper driver will give you an at least 1/2 step (using a l298n only) if I'm right, but most will do even up to 1/32 if not 1/64, this makes a 0.45º motor unnecessary. I don't know if you already know that; when I started designing CNC machines I also was focused on a 0.9º motor but know now that a 1.8º motor will do just fine ;).
    -Ronald
    Edit: changed values, 0.45 to 0.9 and 0.9 to 1.8 º...
    #6 Ronald van Arkel, Jun 23, 2015
  7. Adam Roberts
    Yeah I did consider micro-stepping, but I think that these microsteps are not as accurate as full steps. I think ultimately a 0.45º motor with 1/32 microstepping will have better repeatability and precision than a 0.9º motor with 1/64 microstepping. Do you agree?
  8. Ronald van Arkel
    That would sound logic, but in practice it will give you for 99.9% the same results. I forgot that on OpenBuilds we only have the 1.8º motors, I also edited one post up that I made as I wanted to say 0.9 and 1.8º.
    Any way, 1/16 step with stock NEMA17 and 14t pulley will give you a resolution of 8.75 micron. You will only go to a full step to get more torque out of a motor, something that isn't needed with a 3D printer, except for the extruder although the grip of the extruder pulley is the limited factor there in most cases.
    -Ronald
  9. Adam Roberts
    that reminds me of another thing I wanted to talk about actually!
    I have been reading that a smooth idler wheel is not ideal for belt driven motion, and either a toothed idler or twisting the belt so that the smooth part of the belt rides on the idler would be better.
    Do you have anything to say about this?
  10. Adam Roberts
    As an aside, does openbuilds offer custom parts? I might need an aluminium L bracket with slightly different dimensions from what is available on the store
