Nema 17
Discussion in 'Motors' started by Aime, Mar 16, 2021.
  1. Aime
    Aime New
    Can I use a 24Volts power supply for nema17 stepper with a SKR v1.3 32 bit board and A4988 motor driver modules
  2. ljvb
    ljvb Well-Known
    Yes, the SKR according to the specs (at least the BigTreeTech page) will run off 12 to 24 V, and the A4988 will run from 8 to 35V.
  3. Nemanja Tacic
    Hello, can I use tmc2100 drivers with cnc shield v3 on top of arduino uno, and nema 17 motors?
    I have drv8825 drivers...can i get quiter joging cnc with tmc2100 drivers? :)
  4. Giarc
    The cnc shield v3 is an an obsolete Chinese knock-off of the Protoneer board. The pin-outs are not accurate after GRBL 0.8. If you really want to use a cnc shield, you can get a current cnc shield 3.51 that has the correct pin-outs from Protoneer here Protoneer | eBay Stores or for more information on how to obtain it: Arduino CNC Shield – 100% GRBL Compatable
    As for the Trinamic drivers, I would assume they would be quieter.
