Nema 17 Belt and Pinion on C-Beam XL Gantry Plate
Discussion in 'Concepts and Ideas' started by KramE, Feb 7, 2021.
  1. KramE
    KramE New
    Hello all,
    Please correct me if I am wrong, but I do not see a stock way to mount a Nema 17 onto a C-Beam XL gantry plate to utilize the belt and pinion design.
    Is there any reason why I can't do something like this and just drill out the 4 extra holes?
    Would the two V wheels provide sufficient belt tension angle/deflection (no idea what the right word is here) to keep the belt on the pully? Can I or should I add idlers here?
    Or is there some obvious reason that I'm overlooking that would cause this idea to be doomed to failure?
    Thanks!
    No reason it won’t work. This plate is just something that was created as the group here was moving away from belts. But again, there’s no reason it won’t work. As you note though it is a good idea to increase the contact area between the belt and pulley perimeter as much as possible. You can go with the extra pair of idler wheels as shown or you might even consider putting just a single wheel in the existing center hole and running the belt under and then up and over.
    KramE likes this.
  3. KramE
    KramE New
    Thanks! I'm planning on putting another vslot wheel in the middle so I'll have to see if idlers would even fit
