Need tough OpenRail compatible V-Wheels.
Discussion in 'Announcements' started by mirage335, Oct 3, 2014.
  1. mirage335
    mirage335 New
    Ordered some polycarbonate wheels for HacDC's Optical Table Robot. Unfortunately, they only fit V-groove extrusions, while I greatly prefer the flexibility of OpenRail.
    As this is a high-precision large-scale machine, obviously, these wheels need to be rigid. . Definitely prefer not to use delrin wheels. However, the hard coat OpenRail seems discontinued, and the steel wheels supposedly depended on on it.
    Is that still the case? What is the best solution available for OpenRail users?
  2. Rob Taylor
    This is definitely relevant to my interests.
    Are there any plans for hard coat V-Slot? That would have been ideal for the project I'm currently working on designing. If there was, what would be the load rating on that using steel V-wheels?
  3. Mark Carew
    Lyrad likes this.
  4. mirage335
    mirage335 New
    Thank you, appreciate commitment to maintaining high-quality products. The 25lbs rating is also immensely helpful.
  5. Rob Taylor
    While I'm putting the mill on ice for a while (cost!) and moving towards simple laser cutting and 3D printing, I'm still interested in how I'll eventually provide guidance in subtractive manufacturing. How do the polycarb wheels stack up against, say, 15mm supported linear slide bearings? 150lb (25x6) doesn't seem like a lot for the forces of metal milling, but I might be wrong.
  6. Mark Carew
    Hello @Rob Taylor
    I found some information that may be useful.
    to help calculate cutting force
    1) what is maximum horsepower? usually a motor is about 800 watts per continuous hp, ok lets say 1 hp machine at close to stalling motor
    1 hp x 33000 ft lbs per min / SFPM (surface feet per minute of cutter)
    so lets say a router cutting aluminum at 1000 sfpm
    1*33000/1000= 33lbs of force
    at slower speed of 100 sfpm
    1*33000/100 = 330 lbs
    at really slow speed of 10 sfpm
    1*33000/10 = 3300 lbs
    Rob Taylor likes this.
