Need details about PWM output of GRBL and Estlcam
Discussion in 'CNC Mills/Routers' started by Mehadi Saki, Aug 31, 2017.
Tags:
  1. Mehadi Saki
    Hi
    I am using Estlcam v10 with Arduino uno and GRBL1.1
    I face some problem. Plz anyone help me.
    Problem 1- How to use low power triggered relay for Spindle on/off?
    Problem 2- How I use PWM output for spindle? I mean wiring of spindle. Is there need any external PWM hardware? I need more details.
  2. phil from seattle
    phil from seattle Journeyman
    I don't have all the answers as I'm trying to figure this stuff out myself.
    #1, if you mean what do you hook up, on grbl 1.1, set spindle max speed to 0 and the PWM output pin is toggled on-off rather than PWM. This needs to be fed to a relay driver as the pin doesn't source enough current to directly drive a relay coil - could damage your Arduino. I'd look for a relay module that you can hook to a microcontroller as it will have a built in driver. Tons on ebay - look for "arduino relay board". Be sure to choose a relay that can handle your spindle current draw. Also, match the trigger voltage to your arduino (probably 5V but could be 3.3V).
    #2 this is pretty specific to your spindle, need more details.
    [edit] be sure to check your grbl configuration, there are a number of options that affect this area.
    #2 phil from seattle, Aug 31, 2017
