Movable stage or movable head for "paint sprayer" application?
Discussion in 'Concepts and Ideas' started by Kevin_Brown, Mar 21, 2019.
  1. Kevin_Brown
    This would be my first build here or anywhere. :)
    I need at least 12" movement in x and y. (Don't need z movement.) And then either a fixed "spray head" mounted above it, or a movable head and a fixed stage area.
    There are a few approaches I could use:
    1) C-Beam XLarge X/Y Table Bundle
    with the black box controller:
    BlackBox Motion Control System
    So for this one, the table would move, and I'd mount the spray head up above it, using a linear rail support structure.
    2) OpenBuilds Sphinx 55 (20" x 20")
    Stage doesn't move, but spray head would.
    3) OpenBuilds ACRO 55 20" x 20"
    https://openbuildspartstore.com/openbuilds-acro-55-20-x-20/
    Same: stage wouldn't move, but spray above would.
    Any thought?
    [Thanks!]
  2. MaryD
    MaryD OpenBuilds Team
  3. Rick 2.0
    Belts will give better speed for painting but the ACRO is probably not stout enough to do the job. You might be better off just building an H-frame with 3 of the NEMA 23 belt driven actuators.
  4. Kevin_Brown
    Not big. It's sort of an 8x8" frame, with 4 parts each in 2 columns. (The parts themselves are ~2x3.5".) The frame and parts themselves aren't taller than 1/2", so I don't have to worry about z much.
    MaryD likes this.
