Motor connections
Discussion in 'General Talk' started by Dale Y, Feb 18, 2017.
  1. Dale Y
    Dale Y New
    Ok, now to figure out motor connections. I am building a 1000x1500 OX design router. Now none of the motor I have seen have wires long enough. I was thinking of making a modular setup putting RJ45 male ends on the motors and RJ45 female plugs wired back to the controller board. Anybody else gone this route?
  2. Giarc
    I just soldered longer shielded wires on my motor wires for my 1500x850mm, but I do not see a reason why it wouldn't work. I am just cheap.:thumbsup:
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    I don't think I would use rj45 connectors for this. It might be out of the current rating for them. The wire gage for rj45 is small too. I think it's 24awg. Aviation connectors work well and aren't too pricy.
    Joe
  4. Giarc
    Ooops! In my mind I got the RJ45 confused with something else. Good catch. As I said, I soldered a longer length of 18 gauge stranded shielded wire on to the motor wires and then I did as Joe said and I used aviation connectors at the control box. I used these: Amazon.com: 5 x Panel Mounting 16mm Dia Screw 4Pin Metal Aviation Connectors Plugs by Gino: Electronics but if you need faster delivery, these appear to be the same: Amazon.com: 5 x AC400V 5 A 4 Pin 16mm Thread Aviation Circular Plug Male Connector: Electronics
    I used the four pin connectors and used one per motor. For limit/homing switches, I put the X and Y on one connector and the Z and Z probe on another. They work great.
  5. Joe Santarsiero
    I used 5pin at the control panel and 4pin at the motor.
  6. Giarc
    Was the 5th pin for grounding the shielding? I wish I would have thought of it at the time. I guess I could get a few more.
    Joe Santarsiero likes this.
  7. Joe Santarsiero
    Yeah. To terminate it in the cab. I didn't think of it initially either and reordered. Then I realized I should've done the same for limits. Even after installing them I still haven't grounded them yet. Another item on the forever growing to-do list..
    Giarc likes this.
