mix NEMA 17 with NEMA 23
Discussion in '3D printers' started by Crchisholm, Dec 22, 2017.
  1. Crchisholm
    I am currently working on converting my 3d printer from belts to lead screws. I decided to do this one axis at a time. The current configuration uses Nema 17 motors and I want to convert to Nema 23 motors. I have just about completed the Y axis conversion by building the hardware on a mock up frame. Now is a great time to think about this, but this means that I will have Nema 17's on the X and Z axis and a 23 on the Y and I wonder if that is going to be a problem when I move the Y axis from the mock up to the live printer. I am using a Rambo mini board for the controller.
    Anyone think I am going to run into issues with a mix of 17s and 23s?
    I love this printer (and therefore don't want to give it up to make the conversion all at once. This has been a work horse for over 5 years and it has given me zero problems, so I figured it's about time to introduce some.
    Charlie
  2. JustinTime
    JustinTime Journeyman
    If each axis has it's own motor there will be no problem mixing them. If one axis, like the z axis, has more than one motor then you may have problem mixing them.
    Having said that, didn't you hear about the 'if it aint broke don't fix it' mantra? :D
    Joe Santarsiero likes this.
  3. Crchisholm
    I was pretty sure that was the case but wanted confirmation.
    Yaeh, I think of that saying with every turn of the wrench. There are three reasons I feel the need to do this. 1) I plan to do the same thing to my OX cnc (belt to lead screw) and i figured this would be a good place to practice. 2) Although i've been happy with the printer, there's always room for improvement and I figure I can get it back to the way it is (that's why I am making my changes on the mock up first. and 3) I have never done this before and thats like catnip to me.
    As stated, I am starting with the Y and next I will tacke the X so by the time I get to the 2 Z motors, I should be an old hand (or just old) at this.
    Thanks.
  4. crispin
    crispin New
    The NEMA XX/17/23/XX etc number refers only to the size of the case, not the actually motor. Motor rating is independent and varies greatly within each standard frame size. NEMA 23 are *usually* stronger than NEMA 17 but it's not a convention. Match motors that move together but mixing sizes within the same machine is OK.
