Miniature Z Drive
Discussion in 'CNC Mills/Routers' started by Fred Quarles, Dec 18, 2016.
  1. Fred Quarles
    Fred Quarles Well-Known
    With all the latest builds and mods focusing on bigger and badder machines I though I would post about a miniature Z axis slider that I built for a new Laser build called the Junk Box Mini Ox.
    This slider is based on a modified 2040 v-slot to simulate C-Beam. It uses a unique stepper motor that has a traveling lead screw to move the z axis trolley.
    The slider.
    End view. I cut out the center section with a hacksaw, used a drill press and file to make the link piece that ties the plate to the lead screw.
    Where to cut the 2040 to make the mini C-Beam, remove all the green area.
    DazTheGas and GrayUK like this.
  2. Mark Carew
  3. Fred Quarles
    Cute and just right on the Junk Box Mini Ox...
  4. GrayUK
    I like the idea of a perforated bed! If that was accompanied with a pull-out tray from beneath, like a bird cage, I reckon you'd be onto a winner. :thumbsup:
    I don't think it would work on a larger machine without a lot of support, but it is something I will consider on my next build. :rolleyes:
    Good job. :)
    Gray
  5. Anthony Bolgar
    Anthony Bolgar Journeyman
    Do you have a link to where the stepper motor is available from?
  6. Fred Quarles
    This machine is a laser cnc and the perforated plate will allow the down exhaust of fumes for removal. I'll show more detail when I publish the build on the laser forum The drawer below is where all the electronics will be mounted.
  7. Fred Quarles
    It came from Sparkfun.com
  8. Anthony Bolgar
  9. GrayUK
    They have an interesting video on their site reference stepper motors.
  10. Moag
    Moag Veteran
    @Fred Quarles , you're such a great source of inspiration, you defiantly can think outside the box, keep up the great work mate...:thumbsup::thumbsup::thumbsup:
