MDF Delta
Discussion in '3D printers' started by nicklogan, Apr 9, 2014.
  1. nicklogan
    nicklogan New
    nicklogan published a new build:
  2. nicklogan
    nicklogan New
    See attached photos. Reply if you'd like to see more.
    nicklogan
  3. Darkfibre
    Darkfibre New
    Thanks for the pictures! I'll be watching this one.
    What do you mean by 'polyurethaned'? I assume it's to coat the MDF to keep moist out, but what kind of paint or resin are you using, and do you feel it's working well?
  4. damauk
    damauk New
    Looks good. This is actually something I have been planning on doing myself, glad you beat me to the punch and saved me all that work ;). I don't have access to a 3d printer and while the
    Do you have a BOM for the non-MDF parts? Or did you just use the same components as Jonathan Keep?
    PS love the use of off-the-shelf lighting fixture components in your extruder. More please!
  5. nicklogan
    nicklogan New
    I kept good records and took a ton of photos. I'll try to put a BOM up this weekend as a spreadsheet with sources, prices, part numbers, and quantities. The hardest part to find was the IP80 thread acorn nut to make the nozzle.
  6. nicklogan
    nicklogan New
    Polyurethane is a clear tough coating commonly used as a top coat on wooden floors. Every paint or hardware store carries it. I rubbed on 2 coats with a soft lint free cloth. It hardens the surface and hole interiors of the MDF quite a bit.
  7. nicklogan
    nicklogan New
    I posted an explanation on the reprap forum before I found this site. Search for "hardware store hot end" there. Cut and paste on the link wouldn't work for me in this web editor for some reason.
  8. damauk
    damauk New
  9. nicklogan
    nicklogan New
    I added a BOM to the Files section, it's pretty complete except for listing fasteners. I'll add those and more photos soon.
  10. Mark Carew
    This build is looking great @nicklogan and I love the easy to follow build pics and descriptions you have been adding to the main build page :thumbsup: Keep up the good work
  11. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    As has already been said, an extremely clear and well described build. :thumbsup:
    I am looking forward to following your progress @nicklogan
    I agree 100% ;)
    Tweakie.
