Machine dives down at the start of carve
Discussion in 'General Talk' started by DylanPhelps99, Apr 17, 2021.
  1. DylanPhelps99
    Hello, I’m not sure if anyone can help me I’m new to this. After setting my zero points and starting the job my machine just dives straight down into the material? I’m using Fusion360 and I’ve made a few carves prior to this with no problem at all so why is it suddenly starting to do this?
  3. that-jim
    that-jim Journeyman
    Hope this helps, I had this happen to me recently... I found that the post processor setting for safe retracts was set to G28 when I had always used clearance height in the past. When you go to post process check the safe retracts property, bottom right. You can use openbuilds control to set G28 (bottom right of dro). I ran a couple of simple test programs without a bit to explore the options and decide what I like.
    You are taking about the Fusion built in Grbl post? which does a lot of things weirdly (that included)
    Most of our customers do (and more should) use our Post: docs:software:fusion360 [OpenBuilds Documentation]
    We use G53 instead of G28 - much easier to understand and homing is a little easier to setup. Besides, G28 depends on homing anyway to reestablish the offset
    Summary: use the OpenBuilds Fusion360 post. And have standard Homing. Done
  5. that-jim
    that-jim Journeyman
    Yes, I use the 'Fusion built in Grbl Post'. If you are not using that postprocessor ignore my comment.
    #5 that-jim, Apr 17, 2021
  6. Alex Chambers
    @DylanPhelps99 did you check that you have the latest version of the post processor?
    The older versions did that fine too...
    More likely beginners mistake of forgetting to home.
    Lets hold off on more confusing suggestions until the OP reverts. We see this all the time :)
  8. Giarc
    Beginner mistake? I still make that one every once in a while.;)
