Machine cutting 1mm too big
Discussion in 'CNC Mills/Routers' started by Ats101, Apr 8, 2024.
  1. Ats101
    Ats101 New
    Hello all,
    I am in the middle of a project and decided to cut some spacers to aid with the project.
    Because the spacer key needs to be accurate to be of use, I was keen to measure it. The length and width of the spacer I designed on Vcarve is a rectangle measuring 20 x 30 mm.
    The actual cut piece is measuring approx 21mm x 30.8 - measured with Vernier callipers.
    I am working with the Ooznest Workbee 1500x1500.
    I have checked the 1/8 bit and the diameter is consistent with this.
    After the first cut of spacers, I went to check for slack in the axis. There was some in the x axis which I completely minimised when I adjusted the nut block.
    The cut after that was minimally better as quoted above.
    What do you guys think?
    TIA.
    Wizards and tools > Calibration to fine tune your steps per mm - provided its mechanically tight, true and trammed.
  3. Ats101
    Ats101 New
    Thank you - doing it now!
    Use the longest distance possible (100mm default is just entered by default for folks with small machines like our Minimill)
  5. Ats101
    Ats101 New
    I presume the maximum size would be limited by Vernier callipers limit of 150mm?
  7. Ats101
    Ats101 New
    Ok took your advice.
    I cut some 1200mm lengths this morning. On measuring it just now - they measure between 1198 and 1199mm.
    I just cut out a 50x50 square and measures 50.8 and 50.7mm.
    This cannot be steps related right?
    My machine may not be square?
  9. Ats101
    Ats101 New
    I cut the 1200mm length at the front of my machine.
    I cut the 50x50mm square on some scrap which was situated at front middle of my machine.
    I don't see how being slightly out of square could give this inconsistency of acutal cut being larger at 50mm but smaller at 1200mm.
    I'm puzzled??
    Well, then it might be backlash. Hold endmill and give it a firm wiggle - unwanted play will show up as a feeling (sense of touch is orders of magnitude more sensitive than sense of sight) follow the feeling of free play to find the source
    Measure squareness by checking the corner a square cut with a Square.
  11. Ats101
    Ats101 New
    Machine is square.
    Very minimal play when moving end mill side to side and back and forth. No play as such rather just a slight bit of flex.
  12. Peter Van Der Walt
    Cut recipe aggresive enough to induce deflection?
  13. Ats101
    Ats101 New
    its a good thought that crossed my mind. I am using the present settings on vcarve pro. I will reduce feed rate and see what we are left with.
    Thanks.
  14. David the swarfer
    bit are never the stated diameter. that is why very expensive tool measuring devices are used in industry to measure every tool before it is used.
    checked how? the only good way is with a micrometer. vernier calipers are universally known as 'guessometers' (-:
