Mach 3 controller using open builds CONTROL software
Discussion in 'General Talk' started by mbourassa, Oct 29, 2019.
  1. mbourassa
    mbourassa New
    Hi, complete noobie here. I have tried to search myself but came up confused. Can you use the Open Builds Control software using a mach 3 controller? I have read that you can use Mach 3 software on the blackbox. So is it the same opposite? If not, is there a plugin yet to run mach 4 software on mach 3 controllers? Thank you for any help.
    Not sure where you read that, but no, see the FAQ: OpenBuilds BlackBox 4X Documentation
    To run BlackBox you can use any GRBL HOST SOFTWARE, for example, OpenBuilds CONTROL from software.openbuilds.com, or bCNC, CNCjs, UGS2, and many more
    To run a Mach based controller you can use Mach or LinuxCNC
    #2 Peter Van Der Walt, Oct 30, 2019
    mbourassa likes this.
