Low Speed Rough, High Speed Smooth
Discussion in 'Motors' started by Jonathon Duerig, Mar 21, 2017.
  1. Jonathon Duerig
    Jonathon Duerig Journeyman
    In my latest build, I'm driving some of the OpenBuilds high-torque NEMA 23 steppers with a 12v supply and an xProV2 board. I've noticed that they seem to run really smooth at high speeds (5000 mm/min) but very rough on low speeds (250 mm/min). On low speeds, there is audible vibration.
    Is this normal? Or is there some setting I ought to change? I could change the microstepping setting, increase the voltage of the power supply, or maybe even change the controller board. Any suggestions?
    -D
  3. Marti07
    Marti07 New
    Hi Jonathon,
    Reading the discussion indicated by Rick 2.0 I have found pots about how to configure the maximum speed and acceleration, but not about the problem at low speeds.
    Have you solved the problem?
    Now I have this problem and I don't know if it's normal or not.
    If you need more information, tell me! ;)
    Thanks in advanced!
  4. Jonathon Duerig
    I think it is normal for steppers, especially at low voltages. I eventually 'fixed' this problem by upgrading to dedicated power controllers and running my steppers at 48v. But this continues to be the case on my machines that I drive at 12 volts.
