long lead screw 1500+
Discussion in 'CNC Mills/Routers' started by Goofy, May 1, 2015.
  1. Goofy
    Goofy New
    I am looking for a long screw but a little worried about whip any one had luck with a 5 to 6 foot lead
  2. Joe Santarsiero
    Joe Santarsiero OB addict
    Your looking for the critical speed.
    Its based on length, end support types, and I believe minor dia.
    google "Nook critical speed"
    GrayUK likes this.
  3. GrayUK
    Joe.
    Can y0u drop a copy of that "Nook critical speed" in to Helpful Tools section?
    Gray
  4. Joe Santarsiero
    Done
  5. GrayUK
    Thank you
  6. Jonny Norris
    Jonny Norris Well-Known
    You need a ballscrew over that distance.. Leadscrews only for vertical aplications really. Im using a 1500m 20 mm ballscrew with an anti backlash nut and getting |<0.01mm backlash with it. This is a quality ballscrew, there are cheap chinese versions that wont perform anywhere near so really it depends on the quality.
    Video of one here being spun at 2000rpm with no whip:
    Hope this helps
